  • 5
Message 1 of 11
Yellow light hub 3 no WiFi
I’m without WiFi since this morning. I’ve been through the circus rights that are the Virgin site and the app to no avail.
My Hub 3 is displaying a solid yellow base light and I’ve got no internet with work deadlines looming. How do I call an engineer out or get a new Hub sent out?
  • 24.4K
  • 1.4K
  • 3.1K
Message 2 of 11
Re: Yellow light hub 3 no WiFi
Which of these is it doing: https://www.virginmedia.com/help/virgin-media-no-wifi-connection-hub3
  • 5
Message 3 of 11
Yellow power light is on
  • 4.34K
  • 738
  • 1.76K
Message 4 of 11
Have you done a pinhole reset?
  • 5
Message 5 of 11
Yes I’ve done the pinhole reset
  • 4.34K
  • 738
  • 1.76K
Message 6 of 11
I'll flag this for the forum staff.  The Yellow Light Of Doom even after a reset usually means the hub is kaput, and you'll need a new one.  The forum staff can get that sorted for you, and it'll be just as quick but a whole lot less stressful than trying to contact VM by phone.  But it may take a day or so for them to pick up and respond due to high workload at the moment.
  • 4.34K
  • 738
  • 1.76K
Message 7 of 11
Unfortunately it'll probably take a few days, even a week to get a new hub, so if you've got work deadlines coming up, then your options are to use a phone as a mobile hotspot (and if needed and possible, temporarily increase the data allowance?), which if the signal's OK can often be fine for general work requirements.  Or, if your neighbours are near enough and nice enough, you might ask if you can use a guest wifi connection on their internet.
  • 5
Message 8 of 11
Thank you, I’ll try my phone and will await a response from a Virgin staff member re a new hub replacement. Thank you again.
  • 3.38K
  • 194
  • 317
Message 9 of 11
Welcome to our Community forum ffookeer and sorry to hear about your WiFi and yellow that's affecting your internet usage. I've managed to find your details using the information we have on here and can see that there are some high upstream and low downstream power levels on a few channels which will require an engineer visit. I've booked the visit for the soonest available date and you may find the details via your online account  where you can re-arrange it if necessary. I'm aware that you may have deadlines but you can also check via your online account to see if there are any cancellations.
Lisa
  • 5
Message 10 of 11
Hi Lisa,
Thank you. I cannot seem to find the engineer visiting time on My Account can you help please?
