Iliqnrs6
Yellow Light on router hub3
Hello,
I've been having an intermitted internet connection for about 2 months now, I thought that it is time to upgrade but even after upgrading nothing has changed, I ran a diagnostic, factory reset the router but the yellow light is still there. Please cold someone help me, thanks.
Richw1982
  • 372
  • 33
  • 89
Fibre optic
Re: Yellow Light on router hub3
What are your upstream and downstream levels?
Iliqnrs6
How do i see them
SteNix2020
  • 45
  • 11
Dialled in
If you navigate to 192.168.0.1 and click 'Status' You will have Downstream, Upstream etc this will show you your current levels.
Iliqnrs6
Here it is:
https://prnt.sc/155sa9o
Please see the attached screenshot
  • 6.5K
  • 1.01K
  • 1.61K
Hi lliqnrs,
It's best to copy paste the stats into a couple of posts as screenshots are often rejected by the system due to having personal info such as your ip address.
From the Router Status page copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages.
Don't worry if you see an error message when trying to post, just press post again and it should work.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
