Message 1 of 9
Yellow Ethernet hub cable broken
How do I get a replacement as I can’t through to virgin media
  • 31.49K
  • 1.65K
  • 5.51K
Message 2 of 9
Re: Yellow Ethernet hub cable broken
you can bu ethernet cables from almost anywhere.VM do not sell them
  • 1.43K
  • 202
  • 674
Message 3 of 9
Amazon, eBay, even (gasp) Currys/PC world - they're not that expensive.
  • 3.67K
  • 288
  • 516
Superfast
Message 4 of 9
You could probably even buy one whilst your are on your daily/weekly shop at Morrisons/Tesco/Aldi.
Message 5 of 9
Ok cool it there a particular one I should get ? Are there any differences in them?!
Message 6 of 9
Great ty I was looking on Amazon but wasn’t sure if I needed something special as I can’t through to anyone at virgin
  • 1.43K
  • 202
  • 674
Message 7 of 9
Certainly nothing special about the VM supplied cable. Just look out for CAT 5E or higher in the description and whatever length you want, although to be honest, you'd be hard pushed to even find a cable which wasn't at least Cat 5e standard.
Message 8 of 9
Yes I wasnt sure if I needed cat 5,6 or 7
  • 14.81K
  • 622
  • 1.43K
Message 9 of 9
