mbnaeem
Message 1 of 7
Yeelight Smart Bulbs Connection Issues
It seems that the popular Yeelight smart lighting devices are just not compatible with my Virgin broadband network.
I am experiencing the 'Connection timed out' issue when trying to connect my bulbs to the Hub 3.0 for the first time. I have tried everything on various forums I can find and nothing seems to work.
The bulbs do connect to a temporary 4g hotspots so this issues is specific to Virgin.
Has anyone managed to get to the bottom of this?
Any advice is greatly appreciated
Kippies
  • 12.44K
  • 859
  • 3.22K
Message 2 of 7
Re: Yeelight Smart Bulbs Connection Issues
Have you seperated out the 2.4 and 5 ghz SSID's?
mbnaeem
Message 3 of 7
Yes that's one of the many steps I've tried.
Also tried: removing WPA security, adding Mac address of bulb from the hub settings, updating bulb firmware via temporary hotspot connection.
On some forums it says to try and change the DNS to 8.8.8.8. but in order to that I'd have to put the hub in modem mode and connect another less-resistrictive router. Even this hasn't worked for everyone
Kippies
  • 12.44K
  • 859
  • 3.22K
Message 4 of 7
As a TEST, setup a guest network on your hub and set no security. See if they will connect to that.
mbnaeem
Message 5 of 7
Wow I can't believe it. This actually worked!
I connected the bulb to the guest network. Updated it's firmware. Connected back to my original home network and the bulbs remained connected.
Honestly, I can't thank you enough because I've been stuck with this issue for months
Kippies
  • 12.44K
  • 859
  • 3.22K
Message 6 of 7
Sweet!
Glad its working for you, any other hassles come back and ask. We dont always have answers, but we try LOL.
redmodro
Message 7 of 7
Could you add some more information on the fix for this, I have the same issue and can connect to the guest network without password but the lights still wont connect to the main2.4ghz wifi. did you disable the 5.0ghz. which security settings did you use?
