on 04-09-2023 07:44
Morning more of a question than a whine I have a hub 4 1gig broadband and the Wi-Fi is woefully slow 40/50 down . Is this just normal for hub4 or is there an issue with the hub ? The only reason we even noticed is the eero psu packed up and everything switched to hub4 . Wired is fine Xbox is showing1130 down.
Just wondering if the hub is on its way out and do I need a change or not
on 04-09-2023 07:54
40 to 50 Mb/s down is quite normal for any Wi-Fi device that has connected on the 2.4GHz band.
04-09-2023 08:11 - edited 04-09-2023 08:13
On eero it’s 450 down only hub4 painfully slow and that is on 5ghz or 2.4
on 04-09-2023 09:00
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
Do share the results.
on 04-09-2023 20:26
1st picture is hub 4 Wi-Fi 2nd is through eero Wi-Fi
on 05-09-2023 08:46
Both results look like the wireless device's browser does not perform the Realspeed welll.
Do you have a laptop that can repeat the test in Chrome / Firefox / Edge ?
on 05-09-2023 12:09
I do have is that to test via WiFi or Ethernet ?
on 05-09-2023 12:53
I suggest for your interest do both so you can see if there are any odd differences or aspects that failed to work as we saw above.
Be sure to network cable the laptop direct to the Hub ( i.e not via a Mesh node's network port )
