Lhunt
  • 13
Message 1 of 12
Wireless configuration
Have taken my 2.4hz off of auto and set as channel 10, ( have found by doing this i have no issues with ring doorbell) but since yesterday it reverted to channel 1, and each time i change it back it stays for 5 mins then reverts back to channel 1. Anyone any ideas how to stop this?
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 2 of 12
Re: Wireless configuration
turn off smart wifi that should help
____________________
Tony
  • 8.12K
  • 649
  • 1.42K
Message 3 of 12
You should never use channel 10, only available channels to use are 1, 6 or 11.
  • 15.9K
  • 687
  • 1.56K
Message 4 of 12
or use the Four-Channel Deployment 1, 5, 9, 13
Lhunt
  • 13
Message 5 of 12
I'll give channel 11 a go, thanks
lotharmat
  • 770
  • 53
  • 108
Well-informed
Message 6 of 12
download WiFi Analyser and see which channels are being used locally
Lhunt
  • 13
Message 7 of 12
Still having same problem, channel optimization diabled, channel selection still reverting back to channel 1 after a short time, anyone know how this happens?
  • 15.9K
  • 687
  • 1.56K
Message 8 of 12
You just have to face it the hub is no good so use modem mode and get a better wireless router with 1Gb ports.
lotharmat
  • 770
  • 53
  • 108
Well-informed
Message 9 of 12
Sounds like a bug in the hub firmware!
Lhunt
  • 13
Message 10 of 12
 this is what ive got but need help in having it explained (0 I.T experience)
