Wired connection (and wireless too) drops for a second throughout the day for last one month or so. It has become much worse in the last few days. To isolate the problem, I have removed the third party wireless router and put HUB 4 in router mode, and connected my laptop directly to the hub but the drop is still happening.It is very noticeable when I am on video call, or connected to work place. I have checked all the connections, rebooted the hub many times but no improvement. I have set up BQM and it shows severe packet loss. I have given the downstream, upstream and network logs below. Please someone check them and let me know if you see any problem. I have logged a complaint with the customer service but got back the standard reply. Not sure if they have checked the logs/BQM.
DOWNSTREAM
3.0 Downstream channels
25 330750000 1.3 38.6 QAM256 25
10 210750000 1.9 37.6 QAM256 10
11 218750000 1.9 37.6 QAM256 11
12 226750000 2 37.4 QAM256 12
13 234750000 1.8 37.6 QAM256 13
14 242750000 1.7 37.4 QAM256 14
15 250750000 1.7 37.4 QAM256 15
16 258750000 1.9 37.6 QAM256 16
17 266750000 2 38.6 QAM256 17
18 274750000 2.4 37.6 QAM256 18
19 282750000 2.3 38.3 QAM256 19
20 290750000 2 38.6 QAM256 20
21 298750000 1.4 38.6 QAM256 21
22 306750000 0.8 38.6 QAM256 22
23 314750000 0.5 38.6 QAM256 23
24 322750000 0.8 39 QAM256 24
26 338750000 1.1 38.6 QAM256 26
27 346750000 1.1 38.6 QAM256 27
28 354750000 1.3 38.6 QAM256 28
29 362750000 1.3 38.6 QAM256 29
30 370750000 1.5 38.6 QAM256 30
31 378750000 1.1 38.6 QAM256 31
32 386750000 1.2 38.6 QAM256 32
33 394750000 1.1 39 QAM256 33
34 402750000 1.1 39 QAM256 34
35 410750000 1.4 38.6 QAM256 35
36 418750000 1.4 39 QAM256 36
37 426750000 2.2 39 QAM256 37
38 434750000 2.6 39 QAM256 38
39 442750000 2.4 39 QAM256 39
40 450750000 2.3 39 QAM256 40
25 Locked 38.605377 0 0
10 Locked 37.636276 0 0
11 Locked 37.636276 0 0
12 Locked 37.355988 0 0
13 Locked 37.636276 0 0
14 Locked 37.355988 0 0
15 Locked 37.355988 0 0
16 Locked 37.636276 0 0
17 Locked 38.605377 0 0
18 Locked 37.636276 0 0
19 Locked 38.257755 0 0
20 Locked 38.605377 0 0
21 Locked 38.605377 0 0
22 Locked 38.605377 0 0
23 Locked 38.605377 0 0
24 Locked 38.983261 0 0
26 Locked 38.605377 0 0
27 Locked 38.605377 0 0
28 Locked 38.605377 0 0
29 Locked 38.605377 0 0
30 Locked 38.605377 0 0
31 Locked 38.605377 0 0
32 Locked 38.605377 0 0
33 Locked 38.983261 0 0
34 Locked 38.983261 0 0
35 Locked 38.605377 0 0
36 Locked 38.983261 0 0
37 Locked 38.983261 0 0
38 Locked 38.983261 0 0
39 Locked 38.983261 0 0
40 Locked 38.983261 0 0
3.1 Downstream channels
159 96 4K 1840 QAM4096 759
159 Locked 43 4.4 1786017735 6328
UPSTREAM
3.0 Upstream channels
1 23600000 46.5 5120 KSym/sec QAM64 5
2 30100000 47.3 5120 KSym/sec QAM64 4
3 36600000 47.3 5120 KSym/sec QAM64 3
4 43100000 47.3 5120 KSym/sec QAM64 2
5 49600000 47.3 5120 KSym/sec QAM64 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
5 ATDMA 0 0 0 0
3.1 Upstream channels
6 10.0 41.2 2K QAM128
6 OFDMA 200 53.9 1 0
NETWORK LOG
Mon 06/03/2023
17:47:44 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
17:47:44 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
17:20:45 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
17:10:01 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
09:40:00 6 US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
04:22:43 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
04:21:19 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
02:20:48 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 06/03/2023
00:28:13 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
23:12:07 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
23:10:19 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
21:11:54 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
18:15:48 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
16:53:20 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
16:43:28 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
09:56:28 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
07:46:02 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
06:50:43 6 US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
06:28:13 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
04:39:27 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
04:38:02 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
03:18:54 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
03:17:47 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
02:28:30 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
01:08:27 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
00:47:38 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/03/2023
00:08:14 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
22:46:31 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
22:26:05 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
10:50:39 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
10:50:39 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
10:50:20 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
05:48:50 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
02:52:12 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 04/03/2023
00:56:35 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
21:15:37 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
19:02:43 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
18:53:19 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
10:28:25 6 US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
04:28:36 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
04:17:17 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
02:13:22 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
21:45:47 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
21:45:47 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
21:22:22 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
21:03:23 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
11:57:36 6 US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
11:57:36 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
11:07:05 6 US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
08:30:57 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fa1c5c9b06996acb649ac510b7afbbbb6bd74865-06-03-2023
