Hi.
Recently my superhub 3 has started intermittently dropping connections on both wired and wifi. It drop on both wifi bands (2.4 & 5) and takes anywhere from 10 minutes to 45 minutes to regain a connection. It is happening more frequently usually 2-3 times a day at this point.
the connections always drop at the same time, meaning wired always goes down at the same time as wifi and vice-versa.
I have followed every bit of advice on the help section of the website, I have downloaded the virgin media connect app and I have reset and restarted the router multiple times.
All of the hardware is correctly installed, connections are tight on the cables. Ethernet cables properly connected to router and devices etc.
please could anyone advise me on what the problem could be and any possible soloutions?
