  • 5
Message 1 of 11
Wired Connection Slower than Wireless
I have VM 350mbps package. I have a main router supplemented by a TP link up to 1gbps.  I'm getting an issue whereby:
Wireless connection at the router: 180-200mbps
Wired connection at the router 70-90mbps
Wireless connection at TP link 60-70mbps
Wired connection TP link c. 20mbps.
This is across multiple devices Xbox one X, desktop, HP elitebook with consistent results.  Reboot tried, no fault on line.  Any tips appreciated.
  • 564
  • 190
  • 163
Message 2 of 11
Re: Wired Connection Slower than Wireless
Please try a full reboot on the hub, pin hole reset for at least 30 seconds.
The TP link will run slower as its only repeating the internet that its seeing.
Thanks Chris
To PM just hover over my profile picture and click Send Message when the option comes up. Please don't post any of the info I've asked for in this thread as it's public
  • 24.67K
  • 1.42K
  • 3.14K
Message 3 of 11
What do you get wired directly to the Virgin hub rather than the TP Link?
  • 5
Message 4 of 11
Thanks for the response both.
I've done the full reboot but didn't make any difference.
 Straight wired connection into the router is only producing 70-90 Mbps Vs the wireless connection next to the router of greater than 150mbs.
Tried multiple ethernet cables (cat 5 and cat 6).
  • 24.67K
  • 1.42K
  • 3.14K
Message 5 of 11
Forget the TP Link Router.
What speed do you get wired straight into the Virgin Hub using a Cat6 cable?
Cat 5 will only give you a speed of 100Mbps max.
  • 5
Message 6 of 11
Thanks for the response again. Cat 6 did the trick off the router it turns out, so looks like the issue I had off the main router was a cable problem.
In terms of the lesser speed on the tp link, must just be a limitation of the circuitry.
Thanks all.
  • 24.67K
  • 1.42K
  • 3.14K
Message 7 of 11
OK - so what's the situation now with speeds?
  • 5
Message 8 of 11
Spoiler
Wired off the router with cat 6 at 525mbps
Wireless next to router 160-200 Mbps
Wired off the tp link with cat 6  max 40 Mbps
Wireless near tp link up to 60mbps
I realise the tp link would have reduced speeds but wasn't expecting quite the drop off. Sounds like it's to be expected however.
  • 24.67K
  • 1.42K
  • 3.14K
Message 9 of 11
The TP link shouldn't be that slow though.
What model of TP-Link is the router?
  • 5
Message 10 of 11
The model I picked was TL-WPA8630P.
It stated speeds up to 1gbps plus 3 Ethernet outputs. I suspect the socket i have it attached is a separate ring. I was picking up 160 Mbps on a closer socket so the location may be the issue.
