Message 1 of 5
Will the hub 4 improve my WiFi signal
  • Got the hub 3 but weak signal in certain rooms, Will the hub4 improve this
  • 5.91K
  • 1.12K
  • 1.56K
Message 2 of 5
Re: Will the hub 4 improve my WiFi signal
Hello
It will more than likely not make any difference the only advantage with the hub 4 is you can get free boosters with it, the wireless signal will be pretty much the same as it depends on the make up of the premises it is in.
Don't forget that the Hub 4 is only available in areas which currently have 1gbps for selected customers on lower platforms and for customers who take the 1gbps service.
Regards Mike
  • 24.77K
  • 1.43K
  • 3.15K
Message 3 of 5
Unlikely. It’s plagued with all sorts of issues as you’ll see on here and externally posted.
  • 8
Message 4 of 5
I was also considering the hub 4. have been offered it for free. but many are saying it is crap. some say it is fine. so I am still unsure. I remember when hub 3 came out, everyone said it was **bleep**. but it has always been perfect for me. I get 100Mb all over my house (measured). I pay for 100Mb. it may be too new for the bugs to her worked out yet??
  • 24.77K
  • 1.43K
  • 3.15K
Message 5 of 5
Users are beta testers for new hardware.
Don’t forget WiFi speeds don’t form part of your contract.
