on 17-08-2023 09:37
Apologies if this is a duplicate post. I have jsut ordered WiFi Pods.
At the moment I split my 2.4 and 5gz signal as I have a number of smart devices that only use 2.4
Will the WiFi Pods also broadcast the 2 seperate wifi signals (2.4 and 5) or does it only broadcast 1? and if so, which one?
on 17-08-2023 13:34
VM's Pods do not support split SSID.
on 17-08-2023 13:34
Hey @monkeysuncle,
Welcome back to the Community Forums and thanks for the post.
With regards to the WIFI Pod they work best when the WIFI network is joined together and not split. When it is split the Pod will still work but it will only be connected to one of the signals, which depends on which is stronger where you place the Pod. It will carry this signal around but won't be optimised or be the best it could be.
Joe
on 17-08-2023 13:45
Take a look at a RE450 AC1750 Wireless Repeater that will do dual band split SSID
on 18-08-2023 10:08
Thanks, I have one of those at the moment. I was hoping the pods would do it with a mesh network so I could get rid of the TP Link. Even with the same SSIDs, the TP doesnt create a mesh so devices dont auto switch over to the TP Link broadcast.
Doesnt sound like it unfortunately.
on 18-08-2023 10:47
Folks with VM Pods also mention their device is not connecting to the most local Pod, but again it is their device making that choice. The Pod just offer a Wi-Fi service.
