Wifi
Iboyce84
I am having issues with my Wi-Fi connection in some rooms in the house and want to get a signal booster but can’t find anywhere to order one from on the app or the website could someone help with this please
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @Iboyce84
The pods are free on the Gig1 package, Ultimate Oomph, or any Volt bundle, however if you are on any other package then they are £8  a month.
You need to perform the Home Scan using the Connect app in the area where the signal is low(est) or as near to there as possible.  The home scan feature will guide you from room to room to carry out WiFi speed tests. If it finds a potential signal-less spot, it’ll test your broadband speed to the WiFi Hub to make sure there isn’t a problem with your network.
If everything’s okay with the Hub, the app will take you through to order a WiFi Pod to help boost your WiFi connection.
How to perform the scan and order the wifi pods when using the Connect app.
  • Tap Start the scan and then
  • While connected to WiFi, Tap "I’m ready " and then wait a couple of minutes for the scan  to complete, and then tap Continue
  • Tap Add a room, and at on the room you're in, then Start the Scan (do this in every room)
  • When the scan is complete tap Optimise WiFi now if the options shows as that will try and improve the connection in the current room
  • When it shows Optimisation complete, tap Rescan room,  tap Start Scan  and then you can click on Order a WiFi Booster if it shows as an option
If that doesn't work you can call  0800 064 3850 to order the first one
VM will only send out one at a time, and there must be at least  7 days before ordering each one. It's up to three in total depending upon coverage.
Following that if you need additional pods you can order them by logging into /my-virgin-media, as per the info below from https://www.virginmedia.com/wifi-max ?
How do I get a second or third WiFi Pod?
If you’re not getting download speeds of at least 30Mbps in every room with one WiFi Pod, you can request a second or third by signing in to My Virgin Media, clicking on Your Package and following the steps in the WiFi Max tab
Dave
The do's and don'ts.
2 REPLIES 2
Legend
Might just be as well to order one from Amazon or Argos then it will work with all ISPs Hubs / Routers
Hi @Iboyce84
Dave
