5teve383
Message 1 of 5
Wifi
Any clues as to why my wifi keeps dropping out and trying to join Virgin Media as opposed to my wifi box please?
-tony-
  • 16.94K
  • 1.32K
  • 4.01K
Message 2 of 5
Re: Wifi
not sure what you mean - do you have a 3rd party router or some other wifi device - describe your setup
____________________
Tony
5teve383
Message 3 of 5
Re: Wifi
I just have my virgin box which everything comes through and up to a couple of weeks ago my network was the number on the box. Now my devices seem to be trying to log onto a new network called Virgin Media
-tony-
  • 16.94K
  • 1.32K
  • 4.01K
Message 4 of 5
Re: Wifi
do you have the guest network activated it may be that but that usually follows the the standard ssid - failing that is your hub set up as a hot spot - check that in your profile on your account
Tony
5teve383
Message 5 of 5
Re: Wifi
I’ve rebooted the box and all seems well now thanks
