kiva1974
Wifi
Anyone having issues with WiFi this morning?  Keep losing WiFi connection . I've had enough now.  Definitely will be switching when my contract is up
  • 20.62K
  • 2.19K
  • 3.64K
Re: Wifi
are the disconnects only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables?
If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
And what are the various Hub lights showing/doing when this happens?
Also...
Have you checked for “known network faults”?
As well as trying the “check service,” Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level. These may not be listed on the Area Status web page (Areas are not “Geographic” they are billing areas) as that usually only covers faults affecting 1000’s of customers) so phone may give you more info, but even that wont cover problems affecting just a few customers.
