Wifi
Hi, I have problems with my WiFi going slow  and my sonos devices cutting out. I have checked all connections and all is fine. Have also ran the usual tests from the app/website. All I am getting is we’re detecting an intermittent issue and we’re trying to sort this out for you. I was told this was an issue with the app but something is causing a problem. I have also done a port configuration test through my tv which says failed and comes up with different codes.
  • 6.51K
  • 490
  • 859
Hero
Re: Wifi
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
