Dham789
Wifi yellow light
So my WiFi went off a two days ago and a engineer is coming out on Friday but im trying to get the WiFi working myself by following the procedures online about the yellow light on my hub 3 I factory reset the hub a good 3 times now and its still not working and the yellow light is still there can anyone give me any advice because I honestly don't know what else the engineer is going to do
-tony-
  • 16K
  • 1.26K
  • 3.77K
Re: Wifi yellow light
do you have a hub3 - if so then i assume you mean the power light - had you changed the wifi passwords if so the resets will have set them back to default
other than that the tech will look at things and sort it i would hope - thats why he is coming
____________________
Tony
