Wifi won't reach end of garden
My home office is at the end of my garden (60-70 metres). Its on a separate power supply from the house.  How can I get broadband to reach.
  • 25.21K
  • 1.45K
  • 3.21K
Re: Wifi won't reach end of garden
Run a long Ethernet cable down do it from the hub and attach to an AP at the other end
  • 6.05K
  • 1.14K
  • 1.6K
Hello
The best solution is too run Outdoor Cat 6 cable or above from your router to the home office and then place a wireless access point at the end of the cable.
Regards Mike
Anonymous
Not applicable
Run an external Ethernet cable to your home office. It mi...
Run an external Ethernet cable to your home office. It might involve drilling a hole in the wall, but its cheap, secure, fast and full speed. (Ideal for video conferencing), you might get away with a Unifi LR Access Point but it will never be as good as wired.  At the Office end, a cheap gigabit switch will give you 4, 5 or 8 ports. one for your computer, printer, wifi access point etc.  Suggested access point would be this https://www.amazon.co.uk/Ubiquiti-Networks-UAP-AC-LITE-Access-Point/dp/B016K4GQVG/ref=sr_1_4?crid=32...
Cable https://www.amazon.co.uk/Mr-Tronic-Ethernet-Network-Weatherproof-Black/dp/B0816GP5FC/ref=sr_1_6?dchi...
When you say 70 Metres, is that from the Router? Would it be within a 100 metre range is you ran the cable? If its more than 100 Metres then you may be looking at a different solution.
  • 17.59K
  • 1.85K
  • 3.06K
Re: Run an external Ethernet cable to your home office. It mi...
Or a combined switch+access point like this.
https://www.amazon.co.uk/NETGEAR-AC2000-Wireless-Access-WAC124-100UKS/dp/B01N47QKDQ/
  • 302
  • 10
  • 41
Superfast
I have had experience of lighting strikes to overhead cables taking out sensitive equipment. So initially I resolved my problem  using a pair of Microtik SXT 5AC in a point to point bridge. That gave me about 700Mb
I now use OM3 outdoor fibre to run 10Gb to the home office
