Message 1 of 5
Wifi will not work
Never had this happen in 6 years but 3 days ago my wifi has "Disconnected" I have rebooted, done all the physical checks of box and leads, even an area check which all appear good. The lights are on, but nodody home so to speak. I can't use wifi on computer, phone or my firestick... Help appreciated.
  • 24.77K
  • 1.43K
  • 3.15K
Message 2 of 5
Re: Wifi will not work
Does a wired connection work?
You can try a 60 second pinhole reset on the hub as well.
Message 3 of 5
I tried that, but no joy. Thanks though... Really got me baffled.
  • 24.77K
  • 1.43K
  • 3.15K
Message 4 of 5
Do wired connections work?
Message 5 of 5
Big thanks for your help. I had pressed pin in, but then going over message again noticed you said 60 seconds, and I was like "No" ,but turns out that solved it. Cheers👍
