Piers70
Message 1 of 7
Wifi to outer building
Is it totally viable to run a 50m ( waterproof external) ethernet cable straight out of the router down the garden into a laptop?
  • 6.82K
  • 593
  • 1.79K
Message 2 of 7
Re: Wifi to outer building
Yes, maximum run is 100 Mtrs.  Get external grade Cat 6 cable.  Use a WiFi access point that has Ethernet ports in the Outbuilding. That way you will have WiFi and Ethernet.
goslow
  • 5.52K
  • 743
  • 1.99K
Hero
Message 3 of 7
Yes but that would only allow you to plug in the one laptop on the end of the 50m ethernet cable.
If you wanted wifi in the outbuilding you would need to connect a wireless access point on the end of the ethernet cable.
  • 1.99K
  • 129
  • 466
Super solver
Message 4 of 7
Yes, 100m is the limit for a network cable.
  • 35.14K
  • 3.42K
  • 6.69K
Message 5 of 7
Also if you want better than 100/10 Mbps make sure it has 1GB ethernet ports - many cheaper/older models only have 100 Mbps ports - also 3 or 4 LAN ports to connect devices to on wire.
  • 13.91K
  • 1.08K
  • 2.82K
Message 6 of 7
One small point to consider is that Ethernet cable is cheap, so it’s best to run two for contingency sake. My make life easier in the future.
jem101
  • 4.83K
  • 483
  • 2.13K
Superstar
Message 7 of 7
Absolutely true, the cable cost is nothing compared to the time and effort (and cost) of installing it!
