saggy9999
Wifi to outdoor building
i have built my own garden bar during lockdown. Wifi from my hub is not picked up outside and as its on a different electrical circuit to house extenders dont work. I have just run an external ethernet cable from my hub out the wall round my house and into the bar.  What should i now buy to put in the bar to plug ethernet cable into tonguve me wifi in bar ??
jsstevo
  • 6
Re: Wifi to outdoor building
Maybe try a Mesh Network for the house and add one in the pub (something like TP-Link Deco S4) or I think you can plug one of these into your Ethernet and it will provide the WiFi signal.
carl_pearce
  • 4.75K
  • 405
  • 713
Superstar
@saggy9999 wrote:
An access point like:
https://www.amazon.co.uk/NETGEAR-AC2000-Wireless-Access-WAC124-100UKS/dp/B01LWUJU8H
You can change the SSID and password to match the HUB so your devices should just connect, depending on where the are.
