on 02-02-2022 18:11
Hi i have new gigabit broadband im getting 1gig on the box but on wifi im lucky if im getting 200mbps on all devices
on 02-02-2022 18:16
Well WiFi is always a bit of a black art, as they say. So what we need to know is, what speed are you actually getting through the hub, ie is it a connectivity problem or just a wifi problem - and the fixes will be different depending on where is hold up is?
Do you have a laptop, PC etc. that you can connect directly to the hub via a 'good' (Cat 5e or better) cable? If so and you can do a speed test on that, we can possibly rule out a connection issue.
on 02-02-2022 18:19
No bit the virgin box is connected via wired connection that os getting the full gig
on 02-02-2022 19:32
Your expected Wifi speeds are anywhere between poor and good. There’s no number you can put on it speed wise.
