on 03-01-2023 07:30
I’ve seen similar problems to mine and have tried those solutions: Hub reboot, hub reset, wires all out etc but the wifi still drops intermittently. We’re talking 10-15 times a day which isn’t great for work.
Wifi is fine then stops working for a few seconds. When working, speeds are great.
on 05-01-2023 09:41
Hi MrPTeach
Thanks for posting and welcome to the community. I am sorry to hear of any issues with the WiFi. I have ran a system check and all is fine, no issues.
If it's just the WiFi, can you use the Connect App for me - https://www.virginmedia.com/broadband/connect-app - to do a wireless scan in the property which should help with this.
Let me know how you get on
Best,
on 05-01-2023 20:35
When I have signal, it says everything is fine. When the signal drops I can’t access things to check.
-Any other solutions?
Also, it’s an intermittent problem and some days it drops lots and others hardly at all.
on 05-01-2023 20:44
“Intermittent signal issue in your area.” I checked for connection issues via the website.
on 09-01-2023 11:13
Hello MrPTeach,
Thank you very much for joining our Community.
Can I just apologise for intermittent service.
We can run a few tests from here and check on your equipment.
Sadly its not showing anything wrong, So I will need to send you a private message to gain account access and run further tests.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
