  • 25.75K
  • 2.65K
  • 4.73K
Message 11 of 14
Re: Wifi signal inconsistent
If you answer my Q from 2 weeks ago, in message 2, that would help show whether you have a connection issue or just a wifi one.
With that lovely BQM - my money is on wifi only - but you need to "test" that.
Zach_R
  • 1.44K
  • 44
  • 91
Message 12 of 14
Hi @MarkNicholls,
Thank you for sharing your live BQM with us. I've taken a look at it and I can't see any issues with your connection being detected there.
As I can see @jbrennand has raised, it'd be great if we could narrow down if you're experiencing these issues only on a wireless/Wi-Fi connection, or if your wired connection is impacted with the same problem. Are you able to test and confirm this for us? That will help us dictate the next steps.
Zach - Forum Team
MarkNicholls
  • 6
Message 13 of 14
The last time it happened I check my virgin box and that was okay.  Also my heating control was okay.  Both direct wired.
Mark
  • 25.75K
  • 2.65K
  • 4.73K
Message 14 of 14
OK - if the wired connections are ok then on a Hub3, you can try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings and at the same time switch off "channel optimisation" apply and save the settings. All wifi devices will need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub3 users get better wifi performance - but its still no substitute for getting better kit 🙂
To address the wifi, VM now supply “wifi Pods” (not “boosters”). Pods are free to “some customers” but most will be charged £5/month and right now they dont have enough supplies to provide them - unless you have a demonstrable wifi issue.
And at that level of investment you would soon pay off that cost by buying a "better" wireless solution that will be yours to own and use forever and which will cure all your wifi problems.
