MarkNicholls
Wifi signal inconsistent
I have a HUB3 router which is giving intermittent signal strength.
One moment I can have 75% strength, the next as little as 25% or no internet at all.
I have performed a hard reset as suggested after a call to Virgin Media but this has made no difference.
It seems to me as though this router has reached the need of it's life and I need a replacement.
  • 23.86K
  • 2.53K
  • 4.33K
Re: Wifi signal inconsistent
Firstly... Are the dropout issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
What are the various Hub lights showing/doing when this happens?
Gareth_L
  • 6.86K
  • 421
  • 773
Hi MarkNicholls
Apologies that you have had to post on here regarding your hub
I can see you have called and were asked to perform a pinhole reset
Have you been able to do this?
If so has it improved the service
Gareth_L
