Wifi signal dropping
Hi, I have been trying to get in contact via customer chats and phone calls however I am failing to get through. My wifi signal keeps dropping on all devices (wireless) and it’s becoming very frustrating when doing university work or using the wifi for general use.
I have tried restarting the hub, taken all the plugs and wires out, reset it, but the signal keeps dropping regardless of where I am; even if Im sat in the same room as it.
I haven’t even had the box a year and it’s becoming faulty; all diagnostics online say there is no issue in my area and I’m going in circles with the fault fixes which is wounding me up nowhere. Any help?
Tags (3)
  • 24.4K
  • 1.4K
  • 3.1K
Re: Wifi signal dropping
So wired connections also drop?
I have no wired connections, only wireless
  • 24.4K
  • 1.4K
  • 3.1K
Then it’s difficult to ascertain the issue at hand
