Ste_smig
  • 6
Wifi pods needed for poor wifi signal
Hello,
I have been trying to contact VM with a view to getting some of these Wifi Pods, not having much luck. Any help would be great. I have tried to complete the online form to show interest but it won't submit for some reason.
I have VM's one gig broadband which I have no complaints about when connected via ethernet, the wireless, on the other hand, is quite poor out of the hub 4, I thought if I could improve it with these Wifi pods then I would be in lockdown heaven.
Thanks in advance
Steve
  • 20.59K
  • 2.19K
  • 3.63K
Re: Wifi pods needed for poor wifi signal
There are stock supply issues at the moment - perhaps that's why its blocking requests - who knows!
Try calling in to request one as well - call at 08.00 and you should get through quickest.
TBH I would also suggest you look at other options - like buying your own better quality wireless equipment - in case the Pods doesn't work well for you
  • 15.45K
  • 661
  • 1.51K
Pods are not going to help you.
Ste_smig
  • 6
Thanks you both for your speedy replies.
I will keep trying and get my name on the list for some, apparently there is no monthly charge because of the package I am on, so nothing to loose by trying.
The other option is: I have a tp-link, 3 antenna router that my friend says is very good, he also mentioned putting the hub 4 into modem mode and using the tp-link instead of the hub 4. Sounds a bit complicated, I will read through the paperwork and give it a try over the weekend 🤔
Thanks again😀
tehwolf
  • 1.57K
  • 254
  • 378
Superfast
Thanks again😀
A much better option 😉 modem mode can be a bit tricky to get going initially but works well...
Log into the hub on http://192.168.0.1 and select the option to put the hub into modem mode
The hub will then reboot and come back up in modem mode - give it five minutes to settle down
Disconnect all ethernet cables from the hub
Power off the Hub and your router/mesh system
Connect your router/mesh system to the hub via ethernet cable and switch it on - leave it five minutes to settle down
Power on the hub and leave it five minutes to settle down
Should all be working.
RedGooner
  • 1.88K
  • 66
  • 248
Super solver
I second that, MODEM MODE and your own router.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
