Wifi pods hub 5
User12390
Hello
everyone else is getting the same problem
new hub 5, and my wifi pods won’t connect or be found.
help with ‘provisioning’ pods to new hub please?
I have phoned tech support but no call back.
3 REPLIES 3
Call the equipment activation number they may be able to help. It's 0800 953 9500 and you will need the Hub/{od serial number/MAC address from the barcode sticker, and your account number.
Also it can take several days for the App backend to catch up with new Hub installs, so just be patient
honeyraith
I've got the same problem,  vm are sending new pod in the next14 days.
Steven_L
Hey User12390,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having with your WiFi pod at the moment, I would be happy to take a further look into this for you but first I would need to confirm a few details via private message, please look out for my message and we can get started.
Kind Regards,
Steven_L
