SR74
Wifi pod order
can someone please urgently contact me to order 2 Virgin wifi pods. My 5 children are home schooling due to COVID and cannot connect to the wifi due to poor single in bedrooms.
I urgently need to boost the signal as they are not able to join video teaching and are starting to fall behind in critical learning and also GCSE course work.
I have tried to phone many times over the last 24 hours but the cust service line just hangs up after waiting for a long period of time.
thank you for your help in advance.
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Re: Wifi pod order
As convenient as that would be, unfortunately, it doesn't work like that 😕
You'll have to call them to request them.. best time to do that is 08:00 mon-sat or 09:00 on Sundays when lines open and queues should be a bit shorter.
It's worth noting that the pods are only free for customers on the gig package or an "Ultimate Oomph" package.. if that's not you, you'll have to pay £5 per month - i also believe that they only send out one at a time and ask you to test before supplying a second.
If you're not eligible for a free one, you might want to consider investing in your own network equipment - cheaper in the long run and likely to be a better solution..
SR74
Re: Wifi pod order
Hi thank you for the reply
I have the correct bundle etc and have been recommended the solution via a virgin technician.
I have called 10 times in office hours.  Each time the call is either disconnected whilst waiting or I get a recorded message sending me on-line.
I have gone on-line and the advice on the website suggests calling 150 and speaking to agent.
see that issue I have ?
any advice or a DM from a virgin advisor would be most helpful otherwise. Fear another 10, 20 or even 100 calls won’t get me to speak with the right team.
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Re: Wifi pod order
... speak with the right team.
yeah a lot of the complaints here are about the inability to contact VM by phone - welcome to being a valued customer 🙂
As for the right team - anecdotally, the helldesk is unable to place orders for the pods when you call in so you need to be transferred to the tech teams (double-hold queue, sounds fun).
The alternative is that you visit your favourite electrical retailer's website and order a system that would be with you before the weekend is out and fix the problem yourself - guess it depends how much you value your time and sanity! 🙂
SR74
Re: Wifi pod order
Thank you Any recommendations for a non virgin pod solution?
I have tried a booster that works on the electricity ring main, how ever my issue is upstairs and I have 4 separate electric mains circuits in the house. and so this is a non starter.
the pod solution sound like it will work however I would love a product recco if you have one,  thanks again
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Re: Wifi pod order
TP-Link Deco is well-reviewed around here. M4 at the lower end (£100-150) M5 is the next step up (£180-240) and M9 is the premium (£400 or so). select the one that meets the size of your property and the volume of devices connecting etc..
Asus also seem to get a good write up, and the Netgear Orbi range is also, I believe, pretty good.
If you do go with a non-virgin solution, you'll also need to configure the VM hub to work in modem mode, this is straightforward but needs to be done in a specific sequence..
If you do decide to buy your own, come back here and people can help guide you through the setup if you need it...
