on 04-12-2022 09:16
Hi i have plugged in my WiFi pod and waited 24 hrs but it is not detected on virginmedia connect app so cannot run health check etc. I tried a different location and still not recognised. Any ideas, or am i better off cancelling it and just increasing speed drom 250 to 350 see if that helps?
on 04-12-2022 12:18
Increasing your speed won't increase the range of your WiFi.
on 04-12-2022 13:12
Thanks, any idea why virginconnect won't show info or do health check on it?
on 06-12-2022 14:41
Hi Ribbityeah,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
We're sorry to hear you're having trouble running a home scan with your WiFi Pod. As long as there is no light on the pod, this means it is connected and working as it should be.
It can take up to 5 days for it to appear on the Connect App.
If you wait this long and the pod still doesn't show, please try refreshing things to see if this helps.
Keep us posted on how things go.
on 06-12-2022 15:45
Thanks, i don't need to leave pod plugged in 24 7 do i as will be expensive?
on 07-12-2022 10:07
Hi so it has been longer than five days and still not showing connection info in connect app. I have done all you asked. What next please?
on 09-12-2022 14:48
Hi Ribbityeah, thanks for the message and welcome back to the forums.
I am sorry to hear that you are having issues with the WIFI pod, can you confirm if this is still an issue since posting?
Can you check the trouble shooting guide here
Please let us know how it goes?
Chris.
on 10-12-2022 08:42
Hi yes still an issue. The connect app jist says connection unknown so i have no idea if it is working or not
on 12-12-2022 15:09
Hi @Ribbityeah thanks for your reply here.
So in answer to your earlier question, we would advise it's generally best to leave the WiFi Pod plugged in all the time, rather than turning it off and on whenever you need to use this.
Also regarding the Pod itself, are there any lights showing on the Pod?
Additionally, can you try connecting to the Pod via ethernet cable (there should be a port in the Pod), to see if the device itself then recognises the ethernet connection?
Please let us know because if it does, the Pod will definitely be working.
Many thanks
on 19-10-2023 19:57
i got exactly same issue
1st been told wait 72 hrs
then connect the pod to ethernet toward the hub 5 for an hrs, its recognise on ethernet but not wireless
also provide the S/N: number been told thats need to add on the system
almost a week still not working, just Slow blink light
the wifipod work on previous hub 3 no problem
