Psjc1
  • 6
Message 1 of 8
Wifi pod light flashing
Very poor wifi in most of my house with hub 3 . Been recently sent a wifi pod . Tried 3 different locations each for several hours - the white light just keeps flashing . And no improved wifi . Any ideas please ?
  • 3.21K
  • 251
  • 700
Message 2 of 8
Re: Wifi pod light flashing
Try connecting the pod as near to the Hub as possible.  Once paired you should be able to move it further away.
Graham_A
  • 16.56K
  • 2.33K
  • 7.08K
Message 3 of 8
Check your hub settings under Advanced, Wireless settings to make sure that channel optimisation is set to on and the same SSID is being used for both WiFi bands.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
Psjc1
  • 6
Message 4 of 8
Thanks , but We left it in socket right next to hub for 24 hours - no luck
Graham_A
  • 16.56K
  • 2.33K
  • 7.08K
Message 5 of 8
Have you checked the Hub settings as per post 3?
Graham
Gareth_L
  • 6.95K
  • 424
  • 781
Message 6 of 8
Hello Psjc1
Thanks for your post
Sorry to hear the Pod is not working as it should
Have you been able to follow the steps that @Graham_A has kindly suggested?
Gareth_L
Psjc1
  • 6
Message 7 of 8
Managed to speak to someone at Virgin - there was a problem with the connected channel  - took nearly an hour on the phone but they sorted it in the end , thanks.
Ayisha_B
  • 1.46K
  • 50
  • 137
Message 8 of 8
Hi @Psjc1
Thanks for coming back to us with an update.
We are glad to hear our team was able to get this sorted for you 🙂
Enjoy the rest of your weekend.
Ayisha_B
