Wifi pod issue
zoe203
I have plugged my wifi pod into various sockets around the house - including right beside the modem - and the light continues to flash. Instructions say light will flash for 10 mins while connecting then go off, but it never goes off.
any advice?
thanks.
4 REPLIES 4
It may not be activated yet - Call the equipment activation number on - 0800 953 9500 (follow options) and check. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
Legend
Custom settings of Hub Wi-Fi can affect the functioning of VM Pods.
Hub settings required for VM Pods
1. The Hub is in 'Router Mode'
2. Wireless Channel Optimisation is Enabled
3. The 2.4 & 5 GHz bands have the same SSID
4. SSID broadcast is Enabled on both bands
5. Both SSID are protected with the same password.
Kath_F
Hi zoe203,
We're sorry to hear you're having an issue with getting your pod connected.
Checking things here, we can see it is on the account but showing as offline. Can you try plugging the pod in next to the hub and then push the WPS button on the hub for 5 seconds. Wait 20 minutes and hopefully this will then force the connection and you can then move the pod further away so it repeats the signal to the rooms you're having the issue in.
Keep us posted on how you get on.
Kath_F
Kath_F
Hi zoe203,
As a side note, we can see you have some Netgear extenders active. Can you also turn these off before trying to connect the pod as this may interfere with things.
Kath_F
