Just joined
Wifi password has randomly reset
Today my wifi password decided to randomly reset. After an hour or two of trying to connect various things and rebooting the router, I finally logged in to the router and noticed that it had changed.
I didn't change it not asked for it to be reset. It was OK one minute and not the next. nothing else on the router has changed. as I have some DHCP reservations etc. very odd.
Does this happen a lot? Is the router faulty? Do I need to approach Virgin to exchange the router?
Not really happy that this has happened, I usually have a solid connection. Just seems weird that the wifi password should reset.
Ann
  • 25.12K
  • 1.44K
  • 3.2K
Re: Wifi password has randomly reset
Are you sure no one else in the household has changed it?
