Homes4
Wifi not working
My wifi is not working. It is flashing green, I have tried to re set, but it then just comes up with an amber coloured light. With no internet connection.
RedGooner
  • 1.91K
  • 69
  • 255
Super solver
Re: Wifi not working
I would be more worried about the NO internet connection than WIFI.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
japitts
  • 12.1K
  • 1.68K
  • 2.6K
Do wired connections work ok?
In other words - is this a broadband fault, or a router/WiFi fault?
  • 8.46K
  • 675
  • 1.51K
Which LEDs on the hub are flashing green? It could mean the hub has no connection to the VM CMTS at the other end of the cable. Have you phoned 150 to see if there are any problems in your area?
