Wifi not working
Wifi not working on multiple devices
Router switched off for a minute
Router boots up, white light showing
WiFi still not working
Test ran via virgin website says all ok
Router switched off again and back on
Still not working
Any suggestions
  • 11.28K
  • 1.14K
  • 1.8K
Re: Wifi not working
Do you get a connection on a device connected directly into the Hub by ethernet cable?
Devices connected via ethernet appear to be working fine, just the WiFi that is't
  • 2.16K
  • 333
  • 846
Problem sorter
When you log into the router, is the wfi showing as "on"?
And if it is, and you've previously changed the network name and or password, have you tried now using the default wifi settings usually listed on the base of the hub?  The reason I ask that is because there seem to have been a spate of Hub 3s losing customer settings of late.
