ellaindiaeddy
Wifi not working but looks fine
My broadband hub has the white light on yet it won't let me connect any devices to the wifi. Whenever I type in the password (the one virginmedia gave me) it tells me it requires a WPA2 password on my laptop & on my phone that the password does not connect to the network. It never used to say this before it would just connect. I have tried unplugging the hub at the mains, resetting the hub, doing an area check on Virgin media website and running a check on my own hub through the virgin media website and everything is saying its fine even though its not working.
  • 7.97K
  • 823
  • 1.24K
Re: Wifi not working but looks fine
Assuming you have a Hub3.....
Do a  pinhole rest to factory settings.  Push the pin in to its stop point and hold for a "timed" 30 seconds and then add a few extra!  Some say that NOT restarting the router after that works whilst restarting sometimes doesn't - try both ?
After that - do this.  Using the password on the sticker in the hub drawer/base go into the Hub3 settings and in "smart wifi" disable the "channel optimisation".  Then, in advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's (just change 'em to what you like to differentiate = xxxxx2 & xxxxx5) with (the same) password you like,  save settings and restart Hub.  Over wifi you can then select the network that you want each device to connect to individually with the new password.  See if that helps.
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Hi ellaindiaeddy,
Welcome to the community. It's nice to have you here.
I'm sorry to read you are having an issue with the wireless connection.
Do you only get this issue on your laptop and phone? Are other devices connecting ok?
Try the factory reset as jbrennand mentioned above and let us know how you get on
Sam
