Devigirijan
  • 5
Wifi not connecting
The wifi on the phone gets connected only after several attempts and gets disconnected after a while. Its the same for chromesat not connecting and for different phones. Tried switching on and off and forgetting the network. Still having same issue. Hub 3
gary_dexter
  • 31.33K
  • 1.94K
  • 4.22K
Re: Wifi not connecting
Split the Wi-Fi bands. Choose clearer channels. Disable “smart Wifi”.
Devigirijan
  • 5
Can you please give me detailed step by step instructions.
Thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Best done with a cable connected device.
Instructions for Hub 3, Hub 4 is similar.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
