Vickyx1x
  • 8
Message 1 of 17
Wifi not connecting to door bell ring
I’ve just purchased a doorbell bell ring and won’t connect to my wifi keeps telling me connection failed password incorrect but it isn’t, I think it’s something to do with 2.4 and 5 ghz how do I change it
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 2 of 17
Re: Wifi not connecting to door bell ring
Go into your hub settings (192.168.0.1)
Log in
Go to advanced
Go to WiFi
Split out the channels there (suffix the 2.4GHz band with _2 and the 5GHz with _5)
Also disable intelligent WiFi while you are there -
Hope this helps!
Vickyx1x
  • 8
Message 3 of 17
Thank you, I knew it was something like that but i can’t get on I can’t remember my password and I don’t know how to sort it
gary_dexter
  • 32.63K
  • 2.01K
  • 4.46K
Message 4 of 17
You’ll have to factory reset the hub and use the admin password on the base of the hub.
Vickyx1x
  • 8
Message 5 of 17
I’ve managed to get onto it but no-idea how to change anythin on there to get my wifi connected to door bell
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 6 of 17
Can you see the advanced section after you log in?
g0akc
  • 1.6K
  • 130
  • 315
Super solver
Message 7 of 17
Go to the advanced settings and change the SSIDs (network names) so 2.4 and 5GHz are different
https://www.virginmedia.com/help/virgin-media-configure-advanced-settings-on-your-hub
Then follow Ring set up instructions
Our Ring doorbell works fine with our router and did with a Hub 3 having default settings at the time.....
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
Vickyx1x
  • 8
Message 8 of 17
I’m on advanced settings but I don’t know how to change the network names so they are different
Vickyx1x
  • 8
Message 9 of 17
Just changed names but it’s saying To me on my phone when I try connect that this device only supports 2.4 GHz wifi
stabilo00
  • 283
  • 37
  • 57
Fibre optic
Message 10 of 17
Unless its the pro ring door bell it only does support 2.4ghz
