Stephen14
  • 6
Message 1 of 10
Wifi losing connection
Hi all. I'm having an issue where my devices will lose wifi connection for a few minutes at a time. Its happening more frequently now. My hub will flash a green Wi-Fi light whilst I'm disconnected.
Once the light stops flashing my devices reconnect. Has anybody had any problems like this?
MackNev53
  • 26
Message 2 of 10
Re: Wifi losing connection
I am sure you will get this request from others but can you post the logs on this forum
Stephen14
  • 6
Message 3 of 10
How do I access the logs?
Andrew-G
  • 6.92K
  • 1.21K
  • 3.02K
Message 4 of 10
Connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots.  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.
Then we can check for any obvious problems with power, noise or error counts.
Stephen14
  • 6
Message 5 of 10
1419000000-3.536256 qam36
2267000000038256 qam17
3275000000038256 qam18
4283000000-0.738256 qam19
5291000000-137256 qam20
6299000000-137256 qam21
7307000000-1.238256 qam22
8315000000-1.237256 qam23
9323000000-1.437256 qam24
10331000000-1.238256 qam25
11339000000-1.238256 qam26
12347000000-138256 qam27
13355000000-1.238256 qam28
14363000000-1.538256 qam29
15371000000-1.737256 qam30
16379000000-237256 qam31
17387000000-2.237256 qam32
18395000000-2.537256 qam33
19403000000-2.737256 qam34
20411000000-3.236256 qam35
21427000000-3.737256 qam37
22435000000-4.237256 qam38
23443000000-4.437256 qam39
24451000000-4.736256 qam40
Stephen14
  • 6
Message 6 of 10
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
14620000045.5512064 qam3
23260000044.5512064 qam5
33940000045512064 qam4
45370000047512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0060
2ATDMA0080
3ATDMA00100
4ATDMA0080
Stephen14
  • 6
Message 7 of 10
27/06/2021 13:02:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2021 01:55:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/06/2021 17:00:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/06/2021 04:26:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/06/2021 04:26:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2021 18:42:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2021 16:26:31noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2021 16:26:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2021 11:49:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 21:56:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 15:16:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2021 17:30:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2021 04:26:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2021 04:26:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 19:55:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 16:26:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 16:26:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 10:49:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 04:26:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 04:26:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 6.92K
  • 1.21K
  • 3.02K
Message 8 of 10
There's too many T3 timeouts on the upstream, and in my view the 4.7 dBmV range of downstream power values is probably too wide.  When was the hub last rebooted, as in you intentionally powered it off and then on again?
Stephen14
  • 6
Message 9 of 10
I couldn't say to be honest, not for a while though. I'll do that tomorrow and see if that helps. It's a strange issue really, I've had no problems at all today and probably won't for a few days, only seems to happen when everyone is home and all on there devices at the same time.
Thanks for the advice and I'll give that go.
Beth_G
  • 3.42K
  • 213
  • 344
Message 10 of 10
Hi Stephen14,
Welcome to the Community Forums! Thank you for your first post.
I am sorry to hear you've been having issues with your WiFi and hub over the past couple of days - I've been able to locate your account and everything looks to be completely normal on this end and no identified issues with your primary connection. However we can see that there is a WiFi coverage issue.
How have things been since Sunday? Can you please try factory resetting your hub to see if this helps at all? To do this, you'll just need to stick a pin into the pinhole at the back of the hub for at least 60 seconds.
Let us know
Beth
