@Kateaziz wrote:
My virgin TV is also disconnected and that is wired.
Any analyser app you’d recommend? I’m a bit clueless and cannot get through to Virgin for help.
Thanks!!
if your wired devices are disconnecting then it's worth doing some more investigation into what's going on..
firstly set up a BQM post the link to the "live graph" back here (select the sharing link, it will obscure your IP address from the image).
next, browse to the hub on http://192.168.0.1 - don't log in, click Router Status, copy and paste the tables from the Upstream, Downstream and Network Log back to this thread..
