  • 6
Message 1 of 8
Wifi keeps dropping
So as the title says my wifi keeps dropping... now before we all jump on the send details bandwagon here lies my second issue. After following the instructions on how to fix it 😑 (turn on and off, factory reset apparently its now magically fixed)  its actually made it impossible to actually log into the router....
Now my Internet works fine while I'm connected to ethernet (bar me being able to get into my router) and upon further attempts to factory reset my router this also seems to have stopped working. I'm stuck in a select language, input password, change password, passwords incorrect, select language loop.
The main thing that gets me (appart from being on hold for 3 hours to no avail, and a very polite customer service representative hanging up on me) is that the router itself was working fine up until 2 days ago.
I'm beginning to think its a router orientated issue but can't delv into this any more without access to my settings so any advice on this would be great!!
  • 25.23K
  • 1.45K
  • 3.21K
Message 2 of 8
Re: Wifi keeps dropping
What hub do you have?
Did you do a 60 second pinhole reset?
  • 6
Message 3 of 8
Hub 3, pinhole reset stopped working after the first reset.
Every thing on virgin media "help" (if that's what you can call it) section has been attempted.
  • 12.3K
  • 952
  • 1.58K
Message 4 of 8
It may be a good idea to carry out a proper factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
  • 6
Message 5 of 8
Already done done all your basic error handling.
This is what caused the complete inability to log into the routers settings.
It allows me to the select language page click next and then resets to set language.
  • 12.3K
  • 952
  • 1.58K
Message 6 of 8
It sometimes takes 3 or 4 attempts using the 60 second reset.
While you are waiting for VM (it could take a week) persevere with the resets.
Mike Robinson
  • 6
Message 7 of 8
I spent about 4 hours doing this yesterday (many many resets) but to no avail
  • 12.3K
  • 952
  • 1.58K
Message 8 of 8
OK.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
