Wifi keeps dropping
Hi all
I need help with my wifi please.
All my devices lose Internet but are still connected to the WiFi access point.
My Windows laptops both say Connected but no Internet and my phone/tablet say Ready to connect when the quality of the Internet improves.
These happen randomly as my wife and I work from home and she gets kicked off her zoom call on her laptop and my connection is fine.
In the last hour my phone has lost Internet connection on the wifi 5 times.
Wired connections have no issues
  • 7.01K
  • 517
  • 907
Legend
Re: Wifi keeps dropping
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
