nickbagot
  • 21
Message 1 of 14
Wifi keeps dropping out
Having an ongoing problem where my wi-fi appears to drop out, meaning my remote connection is lost for, say, a minute or so. Which is making remote working all but impossible.
Downstream and upstream data here if it helps. If I had a tether, I'd be at the end of it.
BTW, I have no ethernet connection on my laptop.
Cheers, Nick
12030000006.538256 qam9
22110000006.938256 qam10
32190000006.338256 qam11
42270000006.438256 qam12
5235000000638256 qam13
6243000000638256 qam14
72510000005.538256 qam15
82590000005.538256 qam16
92670000005.538256 qam17
102750000005.638256 qam18
112830000005.338256 qam19
122910000005.338256 qam20
132990000004.938256 qam21
143070000004.638256 qam22
153150000004.338256 qam23
163230000004.538256 qam24
173310000005.838256 qam25
183390000005.338256 qam26
193470000004.138256 qam27
203550000003.938256 qam28
21363000000538256 qam29
223710000004.838256 qam30
233790000003.738256 qam31
243870000003.238256 qam32
1Locked38.6153410546
2Locked38.6166611119
3Locked38.9290114198
4Locked38.6195313722
5Locked38.6165114942
6Locked38.6146914944
7Locked38.6153714180
8Locked38.6158714503
9Locked38.6150015222
10Locked38.6146014218
11Locked38.9150314244
12Locked38.6163314006
13Locked38.6181614754
14Locked38.6170115132
15Locked38.6170916087
16Locked38.6163915512
17Locked38.9157813920
18Locked38.6175013950
19Locked38.9173814359
20Locked38.6180614638
21Locked38.6175613639
22Locked38.6177413971
23Locked38.6179614097
24Locked38.6193913853
16030000042.3512064 qam1
24619998241.3512064 qam3
33940009240.5512064 qam4
45370000041.8512064 qam2
1ATDMA0070
2ATDMA0030
3ATDMA0010
4
ATDM
0020
JitteryPinger
  • 1.74K
  • 192
  • 352
Super solver
Message 2 of 14
Re: Wifi keeps dropping out
Have you tried using an Ethernet cable fix the problem.
If I've helped please let me know 🙂 Matt
A 10+ Year Virgin Media veteran, been here through the Up's and the Down's and Down's....
Gigabit 5G Vodafone 5G EE BQM Hub 4 BQM Hub 3 BQM Hitron CGNV4 BQM TT BQM
Technical Support - AV & Networking - Customer Service - Finance - Culinary - Construction
nickbagot
  • 21
Message 3 of 14
I haven't actually. Will need to use a USB to ethernet, which I don't have, but I'll order one.
Cheers, Nick
JitteryPinger
  • 1.74K
  • 192
  • 352
Super solver
Message 4 of 14
It's always a good thing to have on hand, and always recommended to use wired connection for work use in my opinion
nickbagot
  • 21
Message 5 of 14
Yeah, it's a good idea, but four people are connecting to the wifi and we can't all run a cable.
At my GF's house, also on Virgin, I never have a disconnection, so something is obviously up.
JitteryPinger
  • 1.74K
  • 192
  • 352
Super solver
Message 6 of 14
Understood, technology never works the same in one place to another or in different situations... specially WiFi.
The issues could well be an issue with the hub but at the same time it could be an area issue with too many WiFi routers interfering with each other, it could be a fault with the connection to the network.
WiFi is a service that isn't guaranteed for many reasons, mainly because its not possible to make it reliable in all settings, the mention of using wired connection is recommended for crucial connections such as for working or where slight blips will be detrimental such as online gaming.
nickbagot
  • 21
Message 7 of 14
Not sure what you're suggesting as a fix.
JitteryPinger
  • 1.74K
  • 192
  • 352
Super solver
Message 8 of 14
Well currently we need to be testing the wired connection make sure its a WiFi issue and not a broadband issues (ie. Virgin network)
If the issue is WiFi then we can try some resets and separating networks and try resolve the issue, however Virgin don't guarantee WiFi connections so going to them without first checking wired connections isn't going to get you very far.
nickbagot
  • 21
Message 9 of 14
Roger. Ethernet adapter arriving tomorrow. Will take it from there.
nickbagot
  • 21
Message 10 of 14
OK, so Ethernet connected and connection now stable with no dropouts, so I guess it's a Wi-Fi issue. What now?
