Wifi issues
I am having non-stop wifi connectivity issues. I get disconnected few times a day and today my wifi has been out all day. I am having to use my phone e data to post this. I have tried everything they have suggested on the site. Currently waiting 45 minutes to speak to someone on the phone.
I need home internet for my job.
What would anyone do in my situation?
  • 15.23K
  • 1.2K
  • 3.58K
Re: Wifi issues
do you have problems with wired devices - if you have non what are the lights on the hub doing and what colour are they
____________________
Tony
  • 11.9K
  • 927
  • 1.53K
Re: Wifi issues
What is your connection like using a direct connection with a Cat 5E or better cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Options:
Use an ethernet cable to connect the device to the Hub.
Failing that, get hold of some decent Wi-Fi broadcasting equipment.
The problem you have is that VM do not and never have guaranteed Wi-Fi speed or coverage.
Mike Robinson
Re: Wifi issues
Hi.
I don't know what the issue is but it keeps happening. Connection disappears completely and I have to press the reset button to get it back which takes about 10 minutes. I am getting very frustrated with it.
I have a Hub3. Could it be that I need a new one?
Re: Wifi issues
Hi.
I don't have a cable connection. My computer is far away from the hub.
I keep having to reset the hub to get connectivity back.
  • 17.45K
  • 1.84K
  • 3.04K
Re: Wifi issues
10-30 meter runs of Cat5e cable are less than a tenner, get some and connect the computer to it - temporarily as a test - then put it in your "bits drawer".
If it disconnects you have a problem only VM can fix.
If it's fine you have a a wifi problem only you can fix.
