Airtech15
Wifi drops out when 5GHz and 2.4GHz are enabled
I have enabled 5GHz and 2.4GHz on my hub 3 but now the wifi drops at randon points the internet connection is fine as i have a PC connected via eithernet and this connection is solid and doesnt drop off. I have checked the logs and there is nothing in there for the times it drops out.
If i run just 2.4GHz its ok but cant handle the faster speeds. if i run just the 5GHz the printer cant see the network so running just one is not an option.
has anybody else experienced this issue and if so what settings did you change to get round the issue?
  • 15.4K
  • 659
  • 1.51K
Re: Wifi drops out when 5GHz and 2.4GHz are enabled
Look at getting your own wireless router with 1Gb and use the hub in modem mode.
