Hi Nunadragon 👋 welcome to the community! Thank you for posting.
Sorry to hear you have been experiencing some connection issues. I've had a quick look for you and it seems you are currently effected by an outage. It is currently due to end on 27.02.23 at 2pm. You can see updates yourself here 👉 https://virg.in/service or by calling 📞 0800 561 006.
This is an SNR outage. SNR (signal to noise ratio). This is just a technical term for interference of the Broadband signal caused by noise which ingresses on to our network. It's a difficult problem to locate and diagnose. This is because noise can ingress anywhere on our network. As a general rule it's normally caused by customer equipment e.g. loose connections or 3rd party equipment attached to our network. However it can also be attributable to local architecture, e.g street cabinets, cabling or at the origin of the signal which we call the Headend (servers/routing system).
The only way to establish where the noise is originating is for the Network Techs to run a series of trace routes. Once found then the cause dictates he amount of work required and the time frame for resolution.
The outage is most likely causing the issues you are experiencing, however please do get back in touch and let us know if the outage is confirmed as ended and you are still experiencing issues with your connection so we can investigate further and offer support.
Thank you for your patience in the meantime! Wishing you all the best. 🌞
Molly
