  • 5
Message 1 of 5
Wifi dropping
My wifi keeps dropping out downstairs and is virtually on existent upstairs, after spending 1hr 38mins on the phone/hold to Virgin they cut me off, not before advising me i had to pay £3 a month for a booster, thats not going to happen after i already pay way too much for poor service.
  • 11.38K
  • 888
  • 1.45K
Message 2 of 5
Re: Wifi dropping
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 5
Message 3 of 5
Re: Wifi dropping
Thanks Mike for replying.
Unfortunately i cant connect the router direct to anything as i haven’t got long enough cables and cant move the router closer.
  • 11.38K
  • 888
  • 1.45K
Message 4 of 5
Re: Wifi dropping
OK.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 24.32K
  • 1.39K
  • 3.09K
Message 5 of 5
Re: Wifi dropping
You don't pay for wifi though, so they are correct in offering you the boosters for an additional fee.
Or you need to source your own router and/or mesh system to extend your wifi.
