Experiencing terrible intermittent WIFI, I'm currently on the 100mbs package, which used to work fine but for the past 3 months has had constant issues with the connection dropping
Area status on the app states there's never any issues. Running tests come back everything is fine. I have tried resetting, running tests, checking cables etc so this is not an issue that can be fixed on my end.
As you can see in the network logs, the router is constantly getting errors when the connection drops.
Router info in next post
Thanks for your help
