kenzie1
  • 23
Message 1 of 11
Wifi deadspot
Hi i have 2 sons at home doing home learning and they need to do live lessons bit they have wifi deadspots in their rooms.ive tried everything to sort it out but cant get it to work and its affecting their schoolwork now with dropping oit of lessons.so i saw an ad about the virgin media poweline plugs and was wondering if i could get some?.
Please help
Tags (1)
MrJB73
  • 11
Message 2 of 11
Re: Wifi deadspot
Plugs could help - but possibly better to get an extension mesh system or similar. No way you could run a ethernet cable to the rooms temporarily? Flat cables can fit under carpet:
https://www.amazon.co.uk/CSL-Ethernet-Gigabit-1000Mbit-Broadband/dp/B014DW3VI8/ref=sr_1_3?dchild=1&k...
kenzie1
  • 23
Message 3 of 11
Re: Wifi deadspot
I want the plugs as with all going on ive lost my job and cant afford to spend money and would get the powerline plugs off virgin media as part of my subscription and free but thanks for your reply.
kenzie1
  • 23
Message 4 of 11
Re: Wifi deadspot
Also was on hold on the phone for 60mins then just as they were answering they put the phone down on me so im not happy about that aswell...
gary_dexter
  • 28.86K
  • 1.76K
  • 3.77K
Message 5 of 11
Re: Wifi deadspot
Running by Ethernet would be more stable
kenzie1
  • 23
Message 6 of 11
Re: Wifi deadspot
That's why i want the powerline adapters so i can plug into a socket then use an ethernet cable to the laptops.
gary_dexter
  • 28.86K
  • 1.76K
  • 3.77K
Message 7 of 11
Re: Wifi deadspot
Can you not wire straight to the hub?
kenzie1
  • 23
Message 8 of 11
Re: Wifi deadspot
No as the hub is downstairs and my sons laptops are in their bedrooms and have wood floors so can't run flat ethernet cables and that's why im asking for the powerline adapters.
gary_dexter
  • 28.86K
  • 1.76K
  • 3.77K
Message 9 of 11
Re: Wifi deadspot
Virgin offer the "pods" now, but they cost £5 per month unless you're on the Gig1 or Ultimate Oomph bundles.
For £5 per month rental. they're not worth the cost compared to getting your own (better) equipment.
kenzie1
  • 23
Message 10 of 11
Re: Wifi deadspot
ok i will see about acquiring my own equipment to sort it out and thanks for your help.
