HarryTaylor1
Message 1 of 5
Wifi constantly dropping
Our Wifi is constantly dropping. Virgins website says there no issues in the area. I’ve tried to test our hub on the website and an error message pops up saying “Sorry we can’t run a test right now”. I’ve done my own tests on other websites and they clearly show that it keeps dropping. I’ve followed all of the steps on their website but nothing has worked to fix it.
HarryTaylor1
Message 2 of 5
Wifi keeps dropping constantly
  • 35.1K
  • 3.41K
  • 6.68K
Message 3 of 5
Re: Wifi constantly dropping
I have merged you two identical posts
Two things
1) are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
2) if it is a wifi only issue then see this.............
On a Hub3/4/5, you could first try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings At the same time switch off "channel optimisation/Smart wifi” and “ apply and save the settings. All wifi devices will now need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub users get better wifi performance - so its worth trying - but its still no substitute for getting better kit 🙂
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max see.-
https://www.virginmedia.com/wifi-max & https://www.virginmedia.com/broadband/intelligent-wifi
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible it will be £5 or £8 month - you are… and it wont be - just look on the webpage.
If not free to you… you will be charged £8/month (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4) A combination of (2,3).
£30-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage.
  • 1.89K
  • 120
  • 438
Super solver
Message 4 of 5
Re: Wifi keeps dropping constantly
Check for a local fault on 0800 561 0061 - it is an automated service.
If it is a Windows computer that keeps dropping the WiFi it may be time for  Shutdown or sign out >>> Restart
Do the Hubs Upstream and Downstream stats look in spec ?  Copy & paste the text into the thread for a hand in reading them.
John_GS
  • 15.7K
  • 798
  • 1.46K
Message 5 of 5
Hi HarryTaylor1
I am sorry to hear of the WiFi issues. I have done a system check and contacted the faults management team due to a potential area outage. I will be in touch as soon as I know further assistance.
Best wishes,
John_GS
