Lilymac13
  • 11
Message 1 of 17
Wifi constantly dropping
For the past year or so we've been experiencing the worst WiFi signals. I'm currently on the 100mbs package, used to be perfect, when gaming for example we were able to have multiple consoles running at the same time without any lag. Now we can barely stream two videos at the same time never mind do any gaming.
Area status on the app states there's never any issues. Running tests come back everything is fine. Advisors state there's no issues. But clearly there is when I can't even homeschool my children because the WiFi never works correctly.
Have also tried each device with a wired connection and this makes no difference.
I set up a BQM the other day as I've seen people mention this. Here is a live link, though I'm not sure what this all means! Would really appreciate some help!
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e90c35f7fa1bf2a00ba7b18bb170264481676013
Lilymac13
  • 11
Message 2 of 17
Re: Wifi constantly dropping
Adding info from router as I've noticed on other threads this is the usual info asked for.
1 451000000 -0.5 40 256 qam 40
2 267000000 1.2 40 256 qam 17
3 275000000 1.2 40 256 qam 18
4 283000000 1.4 40 256 qam 19
5 291000000 1.5 40 256 qam 20
6 299000000 1.7 40 256 qam 21
7 307000000 1.5 40 256 qam 22
8 315000000 1.4 40 256 qam 23
9 323000000 1.2 40 256 qam 24
10 331000000 1.2 40 256 qam 25
11 339000000 1.2 40 256 qam 26
12 347000000 1 40 256 qam 27
13 355000000 0.9 40 256 qam 28
14 363000000 0.7 40 256 qam 29
15 371000000 0.2 40 256 qam 30
16 379000000 0.4 40 256 qam 31
17 387000000 0.5 40 256 qam 32
18 395000000 0.7 40 256 qam 33
19 403000000 0.9 40 256 qam 34
20 411000000 0.7 40 256 qam 35
21 419000000 0.5 40 256 qam 36
22 427000000 0.4 40 256 qam 37
23 435000000 0 40 256 qam 38
24 443000000 -0.4 40 256 qam 39
1 Locked 40.3 97481 5803
2 Locked 40.3 3829 2264
3 Locked 40.9 3963 2467
4 Locked 40.9 3013 2235
5 Locked 40.3 5022 2667
6 Locked 40.9 4830 5153
7 Locked 40.3 5825 5159
8 Locked 40.9 6416 5087
9 Locked 40.3 7062 5158
10 Locked 40.9 7152 5121
11 Locked 40.9 7896 4885
12 Locked 40.9 8983 2066
13 Locked 40.9 9881 1762
14 Locked 40.3 12182 3031
15 Locked 40.3 17736 3542
16 Locked 40.3 25666 2421
17 Locked 40.3 27388 5828
18 Locked 40.3 31676 6839
19 Locked 40.3 35045 3354
20 Locked 40.3 47278 3115
21 Locked 40.3 54331 3149
22 Locked 40.3 56453 10550
23 Locked 40.9 74811 9131
24 Locked 40.3 85351 8304
___________________________
1 32600000 44.8 5120 64 qam 13
2 39400000 45.8 5120 64 qam 12
3 46200000 46.3 5120 64 qam 11
4 53700000 46.3 5120 64 qam 10
1 ATDMA 0 0 2 0
2 ATDMA 0 0 5 0
3 ATDMA 0 0 3 0
4 ATDMA 0 0 0 0
Lilymac13
  • 11
Message 3 of 17
13/02/2021 12:21:56 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 12:16:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 11:35:50 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 11:35:24 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 11:35:19 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/02/2021 11:35:19 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 16:01:26 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 15:50:28 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 15:50:10 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 14:51:33 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 14:51:33 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 10:29:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 09:15:43 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 09:14:40 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2021 20:50:46 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2021 02:51:33 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2021 02:51:33 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/02/2021 23:46:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/02/2021 11:15:0 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/02/2021 11:15:0 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Lilymac13
  • 11
Message 4 of 17
Can anyone help???
Chris_W1
  • 3.6K
  • 160
  • 204
Message 5 of 17
Hi Lilymac13, thanks for the message and sorry to hear that you are having issues with the broadband connection. I have looked into this and everything is showing as green on this side, we can see that you have 17 devices connected. Can you do a pin hole reset and connect one device to see if anything changes? ^Chris
Lilymac13
  • 11
Message 6 of 17
Thank you.
At the time of your reply there should have only been two devices connected as I was not home so everything was turned off at the plugs apart from two WiFi plugs. When I log into my router, with everything turned on it states there are 12 devices connected so I'm not sure how you're getting 17.
I have tried resetting and connecting only my phone, numerous times over the last year and it makes no difference and your tech people never see any difference on their tests. I've tried an ether net cable with a device and again, no difference.
I've had to change mobile providers to get anbunlimited data package and use that as a hot-spot most days as our devices can't perform basic tasks.
Could you explain why, on the BQM I posted, some days there are up to 12 hours of red, just a constant red block?
I have tried all of the regular tricks over the year, advised by Virgin, which is why I am now here asking the community as this seems to always have a better outcome.
Lilymac13
  • 11
Message 7 of 17
This is an updated network log, since the last one I posted. This also can not be normal?!
20/02/2021 08:19:5 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2021 19:11:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2021 09:05:31 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2021 09:05:31 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2021 04:39:9 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2021 14:19:32 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2021 14:19:32 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Paul_DN
  • 5.23K
  • 307
  • 547
Message 8 of 17
Hi Lilymac123,
Thanks for coming back to us, I am sorry you are still facing the same issue and that it seems to have got worse, I have looked into this our end and have noticed that the hub hasn't been rebooted for 11 days and that the advised pin reset hasn't been done.
I do strongly advise doing the pin reset, please push a pin/paper clip in the hole at the back of the router, once you feel it pressed in hold it for a timed 1 minute, do not reboot during or after and allow 10 minutes to settle after.
I appreciate you advised previously there weren't as many devices connected as we advised this can be due to older unused devices still showing and a pin reset will clear these.
Kind regards
Paul.
Lilymac13
  • 11
Message 9 of 17
Thank you, I have done this four times since your reply and nothing has improved.
  • 20.51K
  • 2.18K
  • 3.62K
Message 10 of 17
Are all of your issues just on wifi connected devices or do ethernet cable connected devices also have problems? If you dont know can you check? What do the Hub lights show and do at the time you lose connection?
I am thinking that this may be just a wifi issue as the VM staff are not seeing issues and just advising a reset - which isn't helping.
